92 phased 2 speedo maxed out
xredneckf150x
Fabius, New York
1992 yamaha phazer 2.
Uni pods
Boyesen power reeds
PSI single
38 round slide carbs
Vmax 600 primary spring
16/33 gearing
121- 144 conversion 1.25 track
Zrt Plastic ski
Havin it on the stand this afternoon after putting on my uni pods. that. Just arrived I started it to fine. tune my system.. a couple short revs. An realized my engagement is. 4000rpms.. I was surprised. To feel the hole shot power as It engaged. At 3/4 throttle on stand the. Speedo buryies. Itself past 100MPH. An rpms an end at like. 9500. What did I do right. or do wrong!! Thanks
Put it on the snow. I bet it will change. I believe the Phazer runs around 7250 rpm stock. With your set up ie pipe and carbs being the biggest improvement and might raise the torque curve a bit, however I would suspect 9500 rpm is quite a ways out of the power band.
Hey I'm just sayin what it did on a stand. I know. It will change with my 195 lbs. On there. But its quite to get to the mph its hitting is all I a sayin
