Got more problems again with my srx 700. When I pin the throttle it will hit 8500rpms again but then it will drop a cylinder it seems like cause it loses all pull and sounds like its sucking to much air. 125psi across the board on all 3 cylinders. Primary and secondary clutches are good. Plugs are good, golden brownish, not lean or running rich. Powervalve cables are great, no pull thrus and the powervalves are clean. No gaskets leaking. The weird part though is I can hold the throttle at 7500-7700rpms myself and it will pull hard to 80mph but if I pin it, thats when it acts as if it drops a cylinder. I'm beyond mind boggled and am pulling my hair out with this. Anybody have this problem before or have any ideas on what else I could try?
