Help with needle setting
shaggyzr2
Central Wisconsin
On my 2000 srx clip is in 4th groove with one plastic washer on top, what postion would this be? if I wanted to go a tad leaner what would I need to do? Thanks
I think I got it figured out now, I didn't see the other washer..it was stuck to the slide. Clip was at 4th groove, one washer on top and one on bottom, I put both washers on top now, that should lean it out a bit. Stock is 3, I was at 3.5 now it's at 3.25. I hope I got this right! Thanks guys
your correct
