sifton Member Joined Aug 24, 2006 Messages 219 Age 58 Location Manitoba, Canada Jan 17, 2014 #1 Any suggestions for me? 1000 ft, I am approx 185lbs. 2000 M Max 700- SLP's- 151" track. Thanks.
00sxrjoe Active member Joined Nov 22, 2008 Messages 1,149 Age 43 Location Maine Jan 17, 2014 #2 Find slps pipe set-up will put ya close they give clutching recommend http://www.startinglineproducts.com/instsheets/09-727.pdf
yammy Active member Joined Nov 7, 2004 Messages 1,008 Age 64 Location mid mich. Jan 19, 2014 #3 8CR weights w/13.3 rivet inside hole w/s/w primary spring 52/42 helix 80* twist 22/40 gearing should get you close!
sifton Member Joined Aug 24, 2006 Messages 219 Age 58 Location Manitoba, Canada Jan 19, 2014 #4 Thanks, good starting point.
