MLESa7990
I have a check engine light flashing on my 03 Viper. Was curious to know if there was a way to pull the code and see what it is? I did have sensors disconnected when I added a handlebar riser to go with the boss seat, but almost positive i connected everything back the way it should be. Sled seems to run and drive fine. Any ideas?
Ding
Darn Tootin'
The Owner's manual has some of the codes, and the Service manual has even more. However, you should find a page in the Tech Pages that has the manual pages for the codes. Basically look for which icons are lit up on the speedo display and then note the sequence of the codes ( on .5 sec, off .5 sec, repeating for 3 times, etc.). Once you have the lit icons and the sequence of flashes notes, simply look them up. If you can't tell or aren't sure, post what you have observed and we can maybe help you out.
Here is a Link
Here is a Link
MLESa7990
Thanks. I will check it out closely when I get a chance and post the results!
SHPViper
I am also having the same issue with my sled. Thanks for the info!
MLESa7990
[video]http://s1133.photobucket.com/user/narsenault05/media/IMG_1657.mp4.html[/video]
So here is a vid of the light going off...any ideas?
I have also noticed the my idle is low. The sled seems to ride fine tho. Took it out for a short 10 miles the other day and aside from the low idle, i did not notice any issues. Sled did not stall due to the idle. I did take about my handle bars and controls when installing the riser, so I am wondering if i forgot to hook something back up or hooked somthing up wrong since my grip warmers also aren't working lol
viperking
It's most likely your grip warmers, I've had that code on two different sleds and both times the grip warmer switch was bad.
