No spark
t-rav
hanmer,ontario
Hey guys a was about to start my sled today after reinstalling my motor all my plug ins are in the right spot and I have no spark now ran before pullin motor out
Start with the simple things that can be easily overlooked. Is the key on, kill switch up, all electrical connections that we're taken apart reconnected correctly. Sounds like a simple fix, just have to find it. Good luck.
Let us know what it was when you find out, just to help the next guy.
When you removed the engine what connections did you remove?
Stator
Pick up
Tps
Temp sensor
Coil feed wires.
Anything else?
Did you make ANY OTHER changes when you had the engine out?
Did you re install the stator and mag properly? (key installed?)
It really has to be something very simple if the engine ran before pulling it out!
If you don't get it today bring it by tonite and I will look it over.
