Code 7 flashes
TopGunnSrx
Livonia, Michigan
Website
www.tsufilmz.com
Ok Ive been seeing 7 flashes on my 2001 srx, after browsing around ive found guys saying its for the servo motor, but on the tech page it says its "abnormal electrical source". It seems to be running fine, im over revving to about 9k because my red HC spring grenaded and I had to toss in the silver one to get me by. I only notice the code after a decent WFO stretch....
Any insight on this? Like I said the sled seems to run just fine....
I believe its the sequence of 7 flashes. I had the the 7 flashes for servo and it was constantly repeating itself and servo did not work. Search entire harness and then pulled the recoil and had an AH HA! Moment. One of the bolts missing out of pick up coil. Flywheel was 99.9% covered with little knicks/scratches/dings. Pulled the flywheel to find what was left of the stator.....AMAZING it even ran! Put a new stator and flywheel and was back 100% so it was definitely electrical of some sort.
Mine only flashes one sequence and doesnt come back for a decent amount of time. I can confirm my servo motor is working when I idled the sled down, I just want to be sure im reading the code right as I believe the '01 was different.
the 7 flashes is for servo lock, usually its the wires have rubbed thru for the power supply on the clutch side of the sled, check down at cdi box also. I would check the adjustment of the exh. valves as if they are too tight it can sometimes throw this code.
as far as your clutch revving to 9000rpm its not from the silver spring as that spring is weaker then the red, red is 230/360, and the silver is 230/330, so you need more weight in the tips of the clutch weights.
