I have a 97 vmax xtc 600 that has no power anywhere cant get reading on anything. Mechanic said could be broken wire. But could be $$$$. Any help or suggestions would be greatly appreciated.
Could be broken wire somewhere,Im not sure if the twins had the same rub through issue as the triples. Im guessing this is a sled with electric start, is there power at the battery??
It does has the elcetric start but no battery or even cables I have seen
Sent from my USCC-C6721 using Tapatalk
Ok so the sled starts then??
Or are you testing voltage while someone else is pulling the sled over?
No cause I don't have spark.
Yes I don't get anything. No power to coil no power to headlight.
mrviper700
VIP Lifetime Member
check the main fuse if its electric start sled.
