Hammer Down
Trying to get viper skid back in. I have front bolts in on skid. I got the rear 3 bolts in on both sides. I can't seem to be able to line up the top idler shaft that is attached to the shock. I also tried pulling rear mount bolts out but that didn't seem to work either. I took the day off work to get this in so I really appreciate some pointers. Thanks
put the front 2 bolts in first loosely but started good into the threads, then remove the bottom transfer rod bolt completely,the one that goes up into the transfer rod with plastic shim.
then install the middle bolt and then the rear bolt with reinforce plate. by removing the bottom transfer bolt it will allow you to move the upper shaft to align up in the tunnel.
reinstall rear transfer rod bolt and shim.
Hammer Down
Thanks Mr. Viper That made it easy;Got er done. 192 new chisels, she hooked up real good.
