95 Yamaha Vmax 600 witing issues, Please help!
xtreamfish
Eau Claire, Wi
95 Yamaha Vmax 600 wiring issues!!! Sorry for the typo in the headline!! I just bought this sled! I’m at a loss for the wiring at this point! Problems I am having is high beam won’t work after pushing button, in lue of this after its pushed I loose my tack! With the low beam on the oil light comes on and the low beam is dim with the key switch plugged in. I tested the headlight switch and seems to work properly! I seen in another forum that it could be the ip cluster Fowling up, so I found a used one and put in the different ip cluster. Now the oil light is still on and tors light is on with low beam, high beam still nocks out tach! I've already tested the wiring that runs to the hood plugs, all seem to be fine! Haven’t tested the harness on the hood to the ip cluster as of yet! The polar freezing in Wisconsin has been unbelievable and limits time outside to work on it! I’ve Google wiring diagrams with no avail! This sled doesn’t have electric start. I’ve had to unplug the key harness due to the fact it dims low beam! I’m pretty quick with wiring, but this has me so frustrated! Any help would be appreciated
I did test the bulb, it works! Their is oil in the tank!
Tyler
I would say you have something shorting out. I had a poo that did something similar once. It end up being a hand warmer was shorting out. good luck
