PhilG
I have a 2009 venture rs gt. got it last year with 4,000 kms know I have 7,400 kms the last Couple of ride of the humming nose is driving me crazy, I don't know if it a bearing or track too. I checked the drive shaft bearing it still had a bit of grease in it so I pack it with more grease. Can someone help me what I should do with the nose? Thanks
			Devilin AblueDress!
Welcome to the site. Unfortunately none of my 2 strokes have a humming nose......maybe its a 4 stroke thing? All the usual the usual things like track alignment, chain case lube, chain itself come to mind. May have better luck on the 4 stroke side.
			PhilG
Thank you. Ya I think it's a 4 strock side thanks again.
			Devilin AblueDress!
The things I mentioned apply to both, Unsure if theres another exclusive to 4 stroke.
			PhilG
I just joined the site, did I post this on the right site so people will see it? Thanks
			mile9c1
Try this site: http://www.ty4stroke.com/viewforum.php?f=55&sid=45814b2940fed738285ef3b4ddc7037f
Also, check your belt.
What speeds are you getting the noise at?  The yamha 4 strokes are quiet enough that you can hear the track howl at certain speeds.  Mine howls around 50 kph so I just never ride at that speed.
