2001 srx stock clutch settings
JERSEYJOE
TUG HILL NY
Can anyone tell me the stock clutch calibration for a 2001 SRX? chutch weights, spring and secondary spring helix number and degree setting?
8Dn 20 weights, 4.5 gram front hole, 3.6 back hole, y w y spring. secondary, red spring, set at 80, 47 degree helix, helix number is 8bv-17604-71-00
also if you want to go fast changed the 3.6 rivet to 4.5 and primary spring to W W W with 1 shim then pick up a Dalton 54/46 and green secondary set it at 70
I'm using that set up in mine but I've got a 51/45 helix, whats the difference between the 51/45 and the 54/46?
