New here, couple questions
Brinkkl2000
West Michigan
Hello all, I have been looking around this forum for quite some time and am very impressed with the wealth of knowledge! I have 2 question however,
1) How does one use the search function. If I even enter "srx" or "700" it will come back and say there are no results...
2) A little more technical... has anyone ever used IPONE Boz 2 lubricant in their chaincase?
Hello and welcome to the site.
As to search, you need to select the area you wish to search in for your information. The forums is usually a good place to start.
As to chain case oil, many members use many lubes as per their preference. I personally use synthetic 75w90 most often. Currently using royal purple 75w140 in my chain cases.as long as it is 80 w oil at some point it should be fine.
