super duper stuck on grips
cut em off. If you want to keep them you can try and use an air nozzle and try and work the grips off. Not sure if you could use a solvent or something on whatever glue was used. Your not trying to get the stockers off are you?
my blue grips on my 01 will fall right off if i pull the rivet. the black ones on my 99 are practically welded on. you got any extra grips around jeff?
Hook the grip wires to a 12 volt battery, one side at a time. When they get hot, gently twist and they will come off.
this trick works awesome be sure to wear some welding gloves or something to protect your hands!
