kking32
just found one of the cleanest 03 vipers iv'e ever seen, only issue is it needs a motor, the owner says its the crank bearings, top end is supposedly still good, just did a quick search locally and found a running 99 srx engine, (cheap) is it possible to use this bottom end with the viper top end and also the viper flywheel and magneto? second quick find was a sx 700 bottom end complete for cheap? i wouldnt want to use the srx pipes etc, going for the stock look!! any input ? thanks
