cam19aro86
Hello,
I was doing some searching and couldn't come up with a good answer so I apologize if this topic has been beaten to death. I have a 99' SRX 600. I really like the sled and mostly use it for trail/lake riding. I want to raise my bars to a good height that it is comfortable to stand up through the trails occasionaly. I am 5' 7, does anyone have any advise, I was thinking about going with 6" 30° risers, will that be to big for what I am looking for?
Thanks!
Thanks!
		super1c
Super Moderator
6" with stock bars will be pretty big.   I did what would be about 4" higher then stock and its perfect as i am also 5'7".   Going any higher then 3" with stock bars you will have to change brake line, throttle and oil cable.  But you will like the rise for sure.  I was ok with the 3" untill i put a boss seat on then i wanted just a hair higher.   I also chaged to apex bars and when with a 1 1/2 pivot riser and 6"block.   This comes out to be about 4" higher then stock bars.
			devinzz1
to high for your height. think a rox 3.5" riser would do nice and your stock cables are "just" long enough if you run em through the airbox
			cam19aro86
Thanks for the help guys.  This may be a stupid question but what do you mean when you say "through" the airbox?
			99srxracer
My buddy got 6" risers on his srx with apex bars. He loves it
			devinzz1
under the top foam piece there should be a slot. Fit the cables in through here instead of up and over the foam
			TopGunnSrx
I have 6" and Pro Taper 1-1/8" bars with the cr hi bend. I needed all new cables (mtn viper) and I purchased a braided brake hose. I like the added width on the pro tapers, and it feels pretty decent to ride both standing and sitting, im 5'8".
			cam19aro86
Thanks for the help,  I think I will try a 3 or 4 inch rise and some mtn max cables.
Sent from my HTC VLE_U using Tapatalk
		super1c
Super Moderator
You don't want mtn max. Cables you want 03 mtn viper cables.   And when you order make sure they have the 8en prefix for mtn.
			devinzz1
You could get some angled rsi risers and order some extended cables at same time.
			cam19aro86
That's what I was planning is the rsi 4 inch risers and I will make sure to use the nth viper cables.  Thans again for all the help
