Oil pump
okanagan
Hey guys new to this site and new to the sport. First of all incredible site. So much info and great guys on here! Has helped me out a ton. I have a 98 yamaha mountain max 600 twin and I have searched for this answer but have not found it. I was wondering if a 99 mm 700 triple oil pump would fit my sled?
Thank you.
Not sure if it would work being from a triple. I have one from a 99 vmax 500 twin for sale. Not sure if it will work though
The oil pump from a triple wont work, the oil pump from a 97 + 500 is the same pump as a 600 but I believe there are small differences.
The pump from a triple won't work, the pump from a 500 looks the same, but has a different part number. My venture 6 has the same exact motor as your mm, smart carbs and all. Went through the same issue, failed pump, and ended up buying a new one.
I have the same problem with my 98 600 twin, drinks oil like my son drinks beer ! I remember that a Exciter oil pump is the fix for the twins ? Anyone ?
The fix is a new pump. It will give the motor the correct amount of oil.
Ya I figured as much. Well thank you for all the info guys. I'll just by a new one.
I just unhooked my pump and premix, worked so far got about 300 miles on it like this.
Sent from my C771 using Tapatalk 2
Hmmm ok cool I herd that the oil pump oils the crank bearing and the water pump bearing or something like that.
