stealther27
Ok so I had been following amato's sweet white srx build and wanted to upgrade my shocks so I did the same as him and got front shocks from a kfx 450r. I used the same trailing arm, but got sxr tie rods. The problem I'm having is lining up the steering arms with the tie rods. I had the handlebars set straight with the skis set a little toe out. I got the left side steering arm and tie rod lined up but Im having problems with the right side. when I put the steering arm on the ski spindle its supposed to be turned to the outside a tad but the only way I could attach it on that side is actually putting it on straight, so then when I took it for a ride the other night I noticed that when I would turn to the right that the little nub that's under the steering arm actually hits the trailing arm and is getting bound up. Im just trying to get everything lined up and I don't know how Im supposed to get the steering arm to be turned to the outside. I also have the little dot that's indented on the top of the ski spindle pointed to the front. Just getting a little frustrated and want to get this all sorted out.
