Hey guys. Im in the middle of doing my clutches and I have a setup on mind just wondering if the experts could give me there 2cents worth in on it.
Primary
8BU 00 Weights 4.5g in the tip nothing in first hole.
Gwg spring
Secondary
Rx1 helix 51/43 I believe
And stock spring @ 70deg
Help would be Great. Without your clutches done right ya got nothin!
I also have stock spring from Rx1 and stock primary srx. And a Gwg secondary (not at the shop right now might just be green)
Primary
Gwg spring
Secondary
Oh ya I run wide open trails and the odd lake
srx heaven!
srx heaven!Only thing I have on it that's not stock is hauck growlers
YAMMIEGOD3:16
woody, i am gonna guess your rpm will be to low. i think your setup will work, but with a different helix.i don,t like a 43 finish with a 4.5 at the tip of 8bu. 3:16 (yammie tony)
Ya I'm looking for something that's gonna take off but not kill itself well trail riding. Maybe 4000~ engage and I don't wanna go over 84-8500
I also have 2.4g rivets too and the stock helix out of it. I kinda like the way the 51 43 shifts if I can find a setup with the gear I got. Going to the lake tomorrow so I'm tryin to find the best setup . I also have the stock weights not sure on the number I'll be at the shop in a few hours.
Any advice with the stuff I got? And buy rpm to low do you mean engage or peak?
Thanks alot!!
Thanks alot!!
And I pretty much have to stick to the 8bu 00 because my stock ones are wore right out.
And I already went threw the clutch chart you guys have (great info by the way!!) But none seem to go with the the parts I have on hand.
it will probably work but your gonna need to make alots of test to get your rpm right ..I think the 2.4 rivets in tip would be good if u run stock gears....just a guess
I'm a tooth up on top 23.
Like I said going to the lake tomorrow any help greatly appreciated!!
this was turks set up, looks like you have most of the parts.
2002 SRX700 1000ft
51/43 Helix, 8-bu weights w/3.6g rivets in tip and 2.4g in 1st hole, WWW primary spring, Green secondary spring
2002 SRX700 1000ft
Ok I'll go get 3.6g rivets in the morning. And 70deg on the secondary sound alright?I'm running at 100-200 ft . What's closest to a www spring? Ill get one if they have one but if not
Just picked up a bender 45-41 helix if anyone has any good setups for that!
YAMMIEGOD3:16
woody try that with 8bu-00 for lake running. this is not a race set-up though. 41 finish might work tad better with those weights. 8bu do not like to be loaded in the finish angle. 38-39- 40 area seems to work better with these weights. especially when you have added alot to the tip like you did. 3:16 (yammie tony)
2002 SRX700 1000ft
Is that with 15,6 mm rollers? lengthening the message by at least 5 characters..
Ok so here's the setup I came up with works really good.
Primary
Bender spring (about 20lbs more of a finish then the Gwg, had them on the spring g tester)
8bu-00
4.5 in the tip
3.1 in first hole
Secondary
Bender racing 45 41 helix
Green spring wrapped at 70deg
Works real good with my 23 38 gearing . Engages about 4000 rpm and holds at about 8550 on top wish I could get it down 50rpm but I think I'll leave it lol
Primary
8bu-00
4.5 in the tip
3.1 in first hole
Secondary
YAMMIEGOD3:16
take secondary to 60 3/3 there will be your 50. 3:16 (yammie tony)
