02 sx viper
chad27
Waukesha wisconsin
Okay I am having problems with my 02 sx viper I need help. Okay here we go, my hand warmers stopped working and now when I hit the brakes the dash goes dead till I let go of the brake level and also when I change from high to low and low to high beams the dash goes dead. Also the dash and headlight dims a lot. The check engine light is NOT on. Please help I am going up north in couple days and want my sled fixed
Sounds like a stator issue or wire harness rubthrough. Check the stator first, sometimes the flywheel may just be rusty, if the stator is the issue lots of stators on here to buy. If it harness rubthrough you'll have to pull the wires from under the engine and fix the wires tape and pull them back through.
