Short srx shocks to get srx lower in front
t-rav
hanmer,ontario
I want my srx to sit lower in the front because I'm only running radar on ice does anyone know we're to get short shocks like pro stock shox or something I currently have the stock Ohlins cannot get it low enought would like about 2 -2 1/2 inches from the ground
Get some very long and thick zip ties.
Loosen your shocks all the way up.
Have your buddy stand on the front bumper to compress the front end.
Run zip ties through the top of shock and bottom of shock
get some 1/8 or 3/16 wire rope and clamps and 4 fender washers for the shock bolts. make loops at the ends of the wire rope to whatever length you want the shocks to be. Loosen the springs all the way on the shocks. remove the nuts from the shock bolts. compress the suspension and put your wire rope over the shock bolts. put on the fender washers and nuts and tighten everything back up. You still want to put some preload on the front springs.
