Viper gearing/clutching
YaMmY_ViPeR
Miramichi New Brunswick
found this setup online. using a heel clicker clutch kit with 40-10 primary weights, grey primary spring, engage rpm 0f 5000 and peak rpm of 8200, yamaha roller secondary, heel-x helix, red secondary spring, 80 degrees spring setting, and running 192 studs, how well would it work? i want a lot of acceleration and still some top end
Go to the TY Home page.
Click on technical pages. Snowmobile tech. Clutches and Jetting.Heelclicker tips.
That'll get you going in the right direction. Tons of info. in the tech section.
