srx extend to 136......whats it take
MSP381
Michigan
I Have Been Out Of The Sport For Ten Years...I Finally Picked Up A 98 Srx600. I Used To Have A 98 700 Srx. I Want To Extend The Track To A 136 And Make It A More Deep Powder Friendly. I Am Looking For Input What I Need To Do Including Handlebars, Etc. I Don't Want To BreaK The Bsnk Though. I Need Suggestions On The Way To Go
Right. I Get That But Who Has Suggestions On Where To Get Then From And What About Lifting The Rear Suspension Out Putting S Different Skid In The Back. What Skid Works Best For The Cost.....Viper,Mm,Sxr,Aftermarket. What About Drivers When Xhanging Over to A 136. Van I Geg A 2" Ttack To FiT
thanks
I don't think a 2" track will fit. I think 1.5" track requires you to remove the protectors, or at least notch the track. Also what ^^^ said. Hartman Inc. seems to be the goto place for the extension. You could always drop another type skid in there if you want but if you go bigger than the stock 121 then you'll still need the tunnel extension.
thanks
Do a search on extending srx or 136 srx ect. Also search for skid replacement. Lots of guys go mono or scIII. Both easy swaps and run great at a decent cost. Plus if keeping proaction you will want to long travel skid which will cost you about the same as a scIII. Then when done with that you will need to raise the front. search long travel front suspension. Start there and read till dawn.
Stay away from Hartman tunnel extension. I used one of his extensions last year on my 07 Attak. Removed snow flap this year to install a longer one and found two huge cracks across the back of the extension. This sled saw limited use. Do a search on the four stroke side for a full description. It will be enlightening.
