Harvey
Lost transfer with my 02 SRX,it always transfered great,all of the sudden it has no transfer,just blows the track right out,even at 40 mph,I had found that my TS-3 transfer rods were froze up,they wouldnt move at all,I got them freed up so they seem to be moving now but still no transfer.what should I look for?broken parts,shocks,pull the transfer rods apart and clean and grease them?looking for some opinions.thanks-Harvey
jwifferdill
Life Member
My TS-3s broke something inside the one of them, and wouldn't allow for adjustment. Had to send them in for repair...now I just run Maxx Perf rods, a much simpler design and cheaper too! Might want to see if your rods actually turn and change the gap or if the grip just spins like mine did.
Harvey
mine have been set at full transfer since new,I ran the adjustment up and down yesterday and sprayed them with pb blaster to make sure they were freed up,something else must be froze or broken,it had no problem pulling the skis up and holding them till you let off before,maybe I have a broken shock.thanks-Harvey
jwifferdill
Life Member
Yeah, a broken shock is a possibility, perhaps the W-arm also. Good luck, I can't imagine its anything too serious. If you run your rods at full transfer its very possible its the W-arm.
Harvey
sucks because I just had the suspension all out to change the track not to long ago and checked w-arm and every thing looked good,oh well,white out conditions right now so I will go work on it.thanks-Harvey
Harvey
shocks are ok,this thing dont straighten out its going to be bye,bye pro-action,hello expert-x-lol-Harvey
