99srx chain gave up, will viper chain work?
linemech31
NH
The chain broke in my 99 srx 700. I have found a guy selling a part out chain case and gears from an 03 viper. After some research i found the part numbers to be different. Has anyone tried running parts from a viper gearbox in there srx of viseversa? I have a 68 link chain, 23t top and 37t bottom in the srx. His viper does not have reverse. Could i swap the whole gearbox too?
it will fit if u run the gear and chain of the viper ......viper and srx 2000-up run hyvo gear and chain ....98-99 srx runs silent chain and gear
Just to clarifiy change all parts ie... gears and chain to make it work? Thanks Modsrx
All good info, I just did that same thing this last Nov. found a set cheap so I shed some rotational weight.
You might want to buy a 23 tooth top gear to keep your gear/clutch setup close to what you had.
Installed today. 21t upper 37t lower. Current setup is 8dn 4.5 each hole. 51\43 helix from apex at 60 wrap. Can't remember what secondary spring at the moment. But it was spot on before the gear change. Haven't had the chance to do any long pulls yet but I suspect it's going to over rev a bit
Sent from my LGL86C using Tapatalk
yep ...the motor will not be loaded at all......u should try to go atleast 22
