Front arms over extending
Nytrozula
Burlington
My son's 1990 Phazer 2 has an issue with the right front shock. When the sled goes over a big bump and the shock is allowed to extend fully the front brackets extend fully and stay in that position instead of returning to the "v" position. Anyone have an idea what is causing this?
Sounds like the bushings are seizing up in the knuckle, take them apart and either replace them or grease them, I take mine apart every year and clean and re grease them. I have seem this many times..
if the arms are sticking straight up and down the pop the rubber cap off and check the shock rod and make sure the 2 nuts and washer are still tight
