8bu-00 weights
tripple_tripple01
newberry mi.
anyone running the 8bu-00 weights? if so what rivets are you using. also wha t helix an springs are you running?, i have a great set-up now but only for a short run. just want a set-up that i can run some top speed blasts
w-w-w primary spring, .8 gram inner rivet, 4.5 gram outer rivet, 50/40 dalton helix , green secondary st 80 wrap.
just wondering what a 53/43 helix would do, i have a 52/42 in rite now, i also have a 51/43. would a 53 first angle get out of the hole quicker??? just wondering, im new to this clutching stuff
Run the 51/43 with the inner empty & try a 4.5 or 3.6 outer. Make sure you got traction.
