1985 phazer running like crap
deekersrx700
Val Caron, Ontario
My son has an 85 phazer that is running like crap all of a sudden. It seems like its at 50% power. I have put new plugs in, cleaned the carbs, checked the spark and everything appears good. Would bad gas give me the same symptoms I'm seeing? Any help would be greatly appreciated.Thanks
check the carbs again and try a new fuel filter if it has not been done recently to your knowledge.
also recheck the head bolts torque. they are known to come loose over time.
ok the head bolts are supposed to be torqued to 11 ft/lb. the head studs/nuts are supposed to be torqued to 18 ft/lb.
try that and then re-check. I know my uncle's phazer the head was so loose that I could grab the spark plug and wiggle the whole thing.
