another powervalv question
MSP381
Michigan
I Got The Parts To Fix The Leaking But I Can't Figure Out How To Disconnect The Cable.....Suggestions Ph
please
disconnect at the power valve ??? just roll the power valve motor u will see the slot on the pv
I Need To Replac The O Rings. How Do You Take The end Off By The Powervavle. I Need To Take Th Cable Off The Parts Closest to The engjne
turn the servo motor with your hand clockwise until you can remove the vale by sliding the wire out of the power valve
