Vmax 700 rod failure
jonmalick
Central, PA
Rod broke today on the 97 vmax 700 and took some chunks out of the bottom case. Anybody have a good spare bottom end and crank that they would part with? Minimum budget.
Anything from a triple red head will work for you, whether its a 600 or 700. They both have the same stroke distance. If you cant find what you need maybe I can repair what you have, pm me if you need to.
Found a bottom end, now when I tore it down, I find out that I need a cylinder and piston. Grrr. It is a non power valved 700 (8CH00).
