exciter carbs
338gpx
N/A
can the kehein round and butterfly carbs be ran with uni-filters instead of the air boxes
mine runs the stock airbox. Most people run them as they seem to run cleaner and throttle response is better. If its good to go with your setup, you should be fine. Do you have the airbox?
ya I run the stock air box just wondered about making more room under hood and easier to work on
