Recommended
VmaxSx600
Lino Lakes, MN
Im looking to get some handlebars for my 98 vmax sx 600, what would you guys suggest as a good set up. i was looking at the fly racing handlebars and hookes with a powermadd 2 inch rise. (i dont want to mess around with the cables so i want the stock cables).
well i put renthal handel bars with knobber bar ends and a 2" rise with no problems on my 600 sxr. renthal are alot better than the stock bars. straighter accross and wider
insane sxr
when you put the renthal bars on your sled what do you do with all the wireing. just use alot of zip ties??? ;):D
i just packed them all under my stock cover. the zippers are a tight fit but they will go if you pull the cover together as you zip. ill take a pic next time im out to the garage
