sledneck1986
Well engine is running good. Everything worked really good. Until the Vbelt blew. So I removed all the junk that was around the primary and put on a new Yamaha 8dn-17641-01 belt. I don't know what was the old belt. Now I have the feeling that the new belt is slipping. The sled feels slower now. At cruising speeds the engine screams now. It was almost sleeping before. I'm pretty sure I've lost top speed too. The RPM's seems to rev quicker, but the sled don't pulls as hard. I checked the height of the belt in the secondary sheave and it was too high, like 3mm above. I removed the shims behind the adjusting bolts and now it's on the 1.5mm spec. But still an annoying free reving feeling. Feels a bit like if the gearing was shorter. Why an old, about to blow belt was making this sled faster than a new belt? I've read a post about different belts and that some people had issues with them. Maybe it's my case. Also I didn't wash the belt, is this step really important? How long for a new belt to ``break in`` ?
Thank you
Thank you
