Brinkkl2000
Hi guys, I am trying to diagnose a no fuel issue and don't know if it could be the fuel pump or not. I pulled the air box and carbs out and pulled on the rope and get no fuel from the fuel lines. There are no leaks in any of the lines that I can see and I am getting a strong pulse from the pulse line. I can draw fuel out of the fuel lines from sucking on them and they do not seem to be obstructed. Is there any way to test a fuel pump? I hate to just start throwing money at this thing...
Throttle Junkie35
If you have good vacuum, the fuel pump SHOULD work. It could have some crud built up in it or a hardened or ripped diaphram causing your issue. It could also be the fuel pick up line has rotted or fallen off. I would run a length of fuel line from a gas can to the intake side of the fuel pump. Give rope a few pulls and see if she pumps. This should tell you if the fuel pump is messed up or not.
