Tjc702
The speedometer stopped working. The bearing went. Would you replace just that bearing or replace the other side to? The sled has reverse so I am not crazy about opening the chain case.
Tjc702
It has 5000 miles on it.
FJViper
Ultimately that's up to you. It is more work for sure but if you take your time it isn't that bad of a job. If they are the original bearings it's just a matter of time before that lower chaincase bearings goes. I did all mine last season and had no idea that the lower chaincase bearing was not long for the world until I got it out.
If you don't do it now I would plan on doing it before next season. Just my 2 cents
