hand and thumb warmers?
Kodman
North Pole, Alaska
hey guys im new to this fourm and need some help i have a 2001 mountian max 700 and my hand warmers
dont work and i tried putting a new switch in and it didnt fix the problem, and my thumb warmer works intermitintly any help would be much appriciated
Are your grips cracked or broken at the end of one of them? If the ends of the grips are moving it can brake the heat wire in them. The wire needs to make a full loop around both grips to connect and work.
Have you checked under the pad to make sure the wire connections are good?
Check that they are tight and clean.
If you have a meter you could make sure you have a complete loop through the grips.
