What weights are these?
04viper700
SESD
Sent from my C771 using Tapatalk 2
There is no marking on these weights, They were in my Mt Viper, Any reason they should be in there? Wanting to put stock 8DN-10 in or should I stick with this weight?
those would have a tendency to trench i would think from the rapid upshift. they are a very good drag race weight and short field riding weight, for deep snow use and mtn riding the 8dn10 will be a smoother more linear power output.
Does anybody have some 8dn-10 they would be willing to trade?
Did you happen to have a pic of the other side? The side shown looks like it is ground down some, enough that the edge feature is ground away. The other side likely had the weight number stamped between the bushing and the rivet.
It is possible they are 8AB's as well, as the profile and hole locations are the same or very, very, very close. The 8CA's are a little thicker in the ramp area and thus heavier than 8AB's. If yours were 8CA but ground down enough, then they could be more similar to 8AB.
8CA = .326" thick, 42.8 grams empty
8AB = .306" thick, 41 garms empty
I know you traded them already, but the new owner might be interested in this info especially if you like him and he's here on this forum.
