rubbersidedown
I have a 02 viper. I needed to replace the drive shaft bearings, case side wore out. So I had a drive shaft from a Mtn Viper with 8 tooth drivers. I had this installed so I can now clear for studs. I have a reverse set up from I believe a 97 XTC that was installed a few years back. My question is what gears should I run now that I have switched to the 8 tooth? And does anyone have a set for sale? Thanks Scott
