Setting the oil pump cable on a Viper ER (02)
SED
Is the correct measurement 20.5 mm.....whats the min and max......thanks
Yes. plus or minus 1mm is spec. That being said, You'll really have to find out what ratio you're using and adjust from there. Should be 50:1.
Really good ratio/mix chart posted by 'Couple of Bucks' the other day. Plus plenty of great reading by doing a search.
