jthemmer
I have the slp triple pipes now and also bought a opticool gasket. I'm a little confused with the srx base gasket. From what I have read are you guys stacking them or only using one or the other? Seems like a dumb question but I just want to be cleared up on it. Other than that I have ordered my mains and pilots to slp's specs. I moved my needle position a long time ago, however now with pipes will I need to adjust again? Slp also claims stock helix with stock spring but can I get better? Right now I have 53/43 with green spring. Next i need to get weights and modify the air box and I'm all good to go correct
