Srx fuel line blowin off
t-rav
hanmer,ontario
I'm having an issue with my fuel line blowin off at the oil pump the first line on the oil pump from the fuel pump is constantly blowing off does anyone know what they'll be causing this
I am guessing the line was replaced with 1/4" fuel line ?
If so go back to 3/16" (hard to go on but fits tight) or if you can find the metric line use that. I had the 1/4" line leaking at the carbs, even with a good clamp installed. I went back to the 3/16" line and it fixed the problem.
It's the stock line almost like its blowing off die to pressure buildup or something never had this issue before and now I've got a code flashing it flashes 3 times fairly quick and stops 3 seconds and repeats I read that it has to do with the temp sensor but it seems fine maybee there is air is the system I dunno
