weak stator maybe??
shaggyzr2
Central Wisconsin
Heres whats going on. My dual headlight just doesn't seem to be very bright, my 97 with single bulb almost seems to be a little brighter. Hand and thumb harmers barely get warm, I keep blowing bulbs in my tach and the sled just doesn't pull as strong as it should, it runs great and has good top end but just doesnt have much for get up and go unless you really hammer the throttle. My 97 700sx is quicker. Has anyone ever experienced problems like this with a weak stator?
dual bulb is the 3d ignition system. in this system ac current is fed from the stator via 3 white wires to the voltage regulator then is turned into 12v dc and that runs the whole sled. seeing that your blowing bulbs, this is usually from a bad regulator.
Hey did you discover what the problem was with your sled not having the pull it should be still working at top end. I have a 2002 Venture 700 and having the same problem. Can you offer any help
