02 Vmax camber specs
snerkman
u.p.
So I've replaced the entire left front suspension on my brother's sled after he hit the tree last spring. What should the camber be set at? I could just copy the other side, but thought it would be good to know the actual setting. Also, is it done with weight on the sled or off? Am I correct that camber should be set before toe? Seems logical.
