Handlebar risers for SXR
sxrpilot
Southern Ontario
I want to install a 2" riser on my 01 sxr7.Am I going to run into any trouble or is there enough cable that it goes smooth.Anyone have any tips? It would be appreciated.
2" riser is just fine. I would add some of the cable chaffing stuff around the electrical wires where they pass through the steering post. I noticed some chaffing so I put that black flexi tube stuff around it and it's been fine for the past 2 years. Just this fall I added a 4" riser with 2" pivot base with Renthal bars. Believe it or not I am thinking that my stock cables will still work. I jut put the motor back in last night and carb rack will be ready by Sat. I bought the stuff to make my own longer cables if I need to but I know the oil cable is long enough and my brake line is fine with the line removed from the bracket behind the air box. No way to tell on the carb's yet. Doug
