SRV Skid
KCCats
IL
1990 SRV, the rear skid is all seized up. The rear limiter strap wasn't even attached?
How does this even function?
do yourself a favor and install a polaris xtra-10, night and day difference. easy install to
I'm planning a skid out of a 98 ZR! This is going into an 86 Ovation!
Well I found the problem! The lower rear arm! WTF A steel outer shaft with a steel inner shaft and a threw bolt! No bushing no grease fitting!
Yep, They are all like that. They had that same rear arm design at least up to 99 on the phazer. If they are greased every couple of years or so they will not seize up.
I could NOT get it apart! I have a 12 t press and heat and all I did was bend it!
I'm using the rear arm out of a 95 Cat skid! WAY better! And all the picots have brass bushings and grease zerts!
Be carefull, I swapped a 07 Phazer skid in my 89 Ovation and now all my buddies want to borrow that old sled instead of riding their RX1 , SRX, Phazer2 .....
Yeah it looks STOCK! Even with the 121!
Now I need atleast a bottom end for the SRV!
