600 twin slide heigth
Hammer Down
Flint
I pulled the carbs off the twin today and noticed the slides are off. How do I set them the same? I noticed one carb has a 'ball' nut under the screw on the arm and the other doesnt. Thanks.
Never mind. Figured it out. What do you guys set the fuel screws to? These were at 2 1/2 TO.
It enables the slide arm to be slightly adjusted up or down. It is drilled off center so when it's rotated the slide moves up or down.
You mean the idler mixer screw? Also it tells you on the belt cover how many turns..be sure not to loose the washer and rubber o-ring inside there! they are hard to come by.
