Installed sidekick scratchers on viper mountain, this way.
robxcr
Hudson Bay, Saskatchewan
So i moved the back pair idler wheels to the inside and attached my sidekick scrathers like so. Good, bad, no ideas?
I can't remember off hand if they clear in that position. One way to be sure is to pull the shocks and run the skid through full travel. Be sure to move the transfer (coupling) full throw while completely compressed.
I was also going to install some scratchers. However, I thought they would perform much better if mounted to the ski's, this way they would spread snow and lubricant toward the center of the tracks rather than loosing most of all of the snow to the outside. Any thoughts as to why not?
They do work well when attached to the skis. The biggest challenge is keeping them from getting damaged, especially when backing up or in brushy areas. It is easy to forget to swing them up out of the way.
Sent from my SCH-I545 using Tapatalk
