jlscudder
Does anyone know if the jackshaft from a 1990-1999 PhazerII will fit on a 1976-1980 Srx so you can use the PhazerII driven? The shafts look close in pictures just not sure if the pillow block will locate in the same place and if the offset will work. I would like to use the SRX pillow block. They both use the same bearing. Thanks Jack
