Cooper0809
Just wondering if a cylinder from an srx can be used in a viper engine or the other way around?
YAMMIEGOD3:16
WELL FOR STARTERS THE POWER VALVES ARE DIFFERENT. 3:16 (yammie tony)
they will bolts there ....srx use oring head ,viper use head gasket ,different power valve ,different porting ...
The casting is also different at the exhaust outlet. The SRX has a raised exhaust "boss" sticking out from the cylinder that is similar in length to the power valve "boss" that sticks out from the cylinder. The Viper also has a "boss" for the power valve, but not for the exhaust. The exhaust outlet is just flat/flush with the side of the cylinder casting.
Cooper0809
Well that pretty much sums it's up eh. Lol
Thanks guys!
Thanks guys!
the only thing they will do is bolt onto the case,everything else is completely differnt and they wont interchange.
