bearing part numbers?
ridesrx
Northeast, IA.
Looks like I have to change the track in my 2000 SX600r. Can I buy the lower chaincase bearing from anyplace other than Yamaha? I will also replace the speedo bearing, as it is original, and it has 3500 miles on it. Those two together are around 100.00 bucks from Yamaha, so I thought I would check with you guys first to see if anyone has figured out a cheaper way.
